I have a teryx I'm having a problem with it spins over fine good fuel pressure and fire but the injectors are not pulsing for the fuel to spray any ideas? It's had the fuel pump changed 6 months ago.
My little boy was riding it just before and ran it out if gas i put more fuel in it and tried to crank it up with no luck i pulled the fuel line off it was spraying out but did not check the pressure on it could it have a pressure switch for the injectors to pulse thanks for the info and your time.
No pressure switch.
Did you read my reply above about roll over or ECU?
