I can't get it to turnover with the key but I can cross the solenoid and it will crank. I have checked all the grounds and connections, can I get some help on this? Is there a way to check the ECU?
Discussion Starter #2
Ok, everything is working except the fuel pump. I can run a hot wire to the wire that feed the fuel pump with 12v and the pump comes on and the bike will start. I tried disconnecting the temp sensor and the fan comes on & I hear the relays click but still no voltage to the fuel pump? I checked the voltage to the roll over sensor and it checked out good. I noticed that I have a brake light on when the key is on? Could it be a short that is keeping voltage from going to the fuel pump? Any help would be greatly appreciated. I am pulling my hair out trying to figure this out....
