2012 Teryx4 was out riding and turned ignition off. When I went back to start it up there is no power or dash lights. Checked the battery, all of the fuses including the main fuse, and power to the solenoid. There is continuity at fuse panel when I turn the key on... Any help would be greatly...
Discussion Starter #2
Found the issue with a volt meter and wanted to share just in case anyone else runs into the same problem.
I found .2 volts at the 30 amp main fuse, when I removed the fuse the white/red wire from the battery would read 12.9 volts but when the 30amp main fuse was installed it would drop to .2 volts.
Two white/red wires are connected to the positive battery terminal and go to a plug connector. I cut the wires above the connector and attached them directly to a new battery terminal and the issue was resolved.
5359
5360
