I need to add a couple rocker switches on the dash
Can I get some help with how to remove the center dash area to replace the blanks with real working switches? Thank You
Just joined and seen your post. The dash pops off easily and is held on by simple clips. Gently pull it off and put it back on the same way. No need to remove knobs or key switch. Hope this helped
The center piece where the stock radio, etc. goes does just pop off easy, but if I want to add a switch to the far left side...how do I get the whole dash off? I've got a plain 2017 Teryx4. I've been unsuccessful so far in about 30 minutes of trying to figure it out. If someone had some directions that would be awesome!!!
Regards,
Brian
Frisco, TX
