Hello,
Its a challenge to get my Teryx to go into neutral so that I can start the side by side. The problem didn't use to be this bad and I could wiggle the shifter around a little bit and get it to go into neutral, but now its a lot worse.
Also have a problem where there is a loud noise coming from the front end when coming downhill in 4WD.
I've did some searching in old posts and it looks like it may be the shift linkage that needs adjusted.
Has anyone had similar problems that were fixed by adjusting the shift linkage?
