1 - 11 of 11 Posts
Teryx belt squeal on take off
The belt or clutch squeals only on acceleration High low and reverse. ANY ideas
Test the deflection. If you want the squeal to go away, you are likely going to have to take the covers off anyways.
The deflection exceeds 22mm to 27 mm. This is removal of shims or is there a tension adjuster?
Belt squeal
Tested the deflection it is way off. to remove the shins is on the primary??
How many shims?
Depends on the how much deflection for which shim.
Back clutch, you will likely need pullers and some time.
if its squeeling while in gear its to tight.if your talking about if chirping when you take off in high its to loose.if its to loose you have to take the secondary clutch off and remove the small shim of the two and it will fix it.if its tight i wouldnt worry about it because it will loosen up
1 - 11 of 11 Posts
