guys,
the last few rides i have had on my 09 teryx i have been smelling antifreeze? it is from the instant i turn the machine on till i turn it off? no drips on the floor??? any ideas!
its not to the low mark, i checked that after smelling it.. so if theres a leak somewhere it must not be too bad?
Check all radiator hose clamps. Mine were finger tight . The hose that i found so lose was the one that i seen on the bottom when i removed the skid plate to change my oil (if i am remembering correctly)
x2 on checking all the hose clamps. Its been a somewhat common problem that the hose clamps are not tightened up fully. They leak just enough to have the levels go down and evaporate due to the heat, so you don't see any puddles on the ground.
guys! thanks for the info i found the leak. It was right above the exhaust near the oil filter, there were 2 seperate clamps and the one that runs above the exhause was dripping direclty on the exhaust! Thanks again!
