Hey everyone, Im new here and was just wondering if there is any common problems with the 09 models. I just got an 09 sport a couple weeks ago and just trying to get the heads ups on anything i need to fix or update.
I would say upgrade air filter. Put on an adapter and a clamp on uni filter. Make sure to service it change the oil in everything often.
Check oil often and do the valve adjustment before 200 hours like the manual says.
Lol Im pretty use to checking oil...I have a 07 Brute Force and it likes to burn a little oil, must be a thing with the 750 v-twin motors. Ive noticed on my brute force that it overheats easy if the radiator gets the least bit clogged or running it really hard, so i ended up putting the aftermarket impeller on it and it helped alot. Is the teryx going to overheat just as easy?
Thank you everyone for the replies and advise. I think I might check into that filter setup and stop kit you got hunterworks, thanks.
It should not be that big of a issue. the 2010 they changed the cooling though.
