I want to put back up lights on the Teryx. What has eveyone been using? I know that the wiring is to the back for the lights, what size bulbs can I get if I use halogen, so I won't over amp the wiring. I was also thinking about putting in LED lights so it would not be a drag on the battery. We ride a lot in the mud and water, will halogens burn up if they get wet? Any suggestions are welcomed!
Thanks for your response, I decided to go with LED's, if that doesn't work out I'll go with the relay and some halogens.
