Have a 2010 Teryx that I bought used this summer. Has low hours on it (120) but of course is 4+ years old. Recently put a Warn 4000DC winch on it but when I attempt to run the winch (direct battery connections) it runs very slow and kills the battery quickly. The battery will charge and will start the vehicle just fine but the winch kills it fast. I am figuring the battery is getting old and I need a new one. What would be the best replacement for the OEM battery?
Discussion Starter #2
Sooo, I went ahead and got a PC925L-A battery. FYI - they install in the existing bracket on their side. The only thing needed is either 8" long 8mmx1.25 bolts to use the OEM hold down bracket - or make a stepped bracket to use the shorter OEM bolts.
