From what others are getting the LEs for, that sounds kinda high. As far as what I do about fuel, when it stops running, then I know it is out
Actually I just have to keep an eye on it, but we have not been on any really long runs, therefore, has not been an issue yet. If the LE has the same fuel window as the standard, then it is worthless, I cannot see anything through it.
I do not have a LE I just went with the standard since everything that comes on the LE would have been taken off anyway when we do the build...therefore, it was not worth spending $1000 more.
If you are going to put a four seat cage on there, then you know the roof and dump bed will not work...you are then left with paying $1000 more for the LED gauge, half windshield, and cup holders. If you can get a good deal on the standard model, you can add the LED gauge later for $219.95
Just a thought
Where are you located?
