while just got done puting a new belt 3800. miles and still looked pretty good yet . adjusted the valves and they needed it i ajusted them at 160 hours and 1700 miles. and now agian at 3800. miles, was getting hard starting , and new plugs to. it needed that to, new tires at 2600 . miles i put on intergo reptiles 9-12-27 front 12-12-27 rear and they dig and nice ride to so still very happy with my rex 2008 :yahoo::yahoo::93C_peelout[1]::93C_peelout[1]::party:
Got some news for you so you should start financially planning on this.
The reason you are having to adjust valves and it getting hard to start is the valves namely the intake valves are deforming and sinking up in the head.
You ARE going to need to replace them and I would not go back with stock valves or stock springs when you do.
I also don't recommend just pulling the head off to do it and putting it back on without changing the base gasket on the cyl and since you're that far, you check the rods for any excess movement and at a minimum replace the rings.
Complete set of good valves $288
Springs $125
valves
ok todd thanks.,,, how soon should i be looking at doing this update and do u have what i need ??? i just want to say thanks to u and hunterworks for all the help u do on these forms .:good::good:u have helped me out alot :good::good:
Shit, iv'e got 5000 miles on my T-rex.How much longer before I'll have to rebuild ?Just finished replacing the front diff ,rear axle ,3 wheel bearings, not to mention all that I did last year ,front axle ,FI fuel pump all the oil seals.Don't forget to check the oil every day,right
That is hard to say, as long as you are not adjusting the valves every few weeks you will be able to buy some time.
Yeah we have the parts or should say have access to them.
Guess we could do a kit and sell it on the site.
No particular time, just keep checking the oil.
Axles and bearing are normal on all vehicles.
Would be curious why you had to replace front diff and running low of fuel a lot will harm the fuel pump.
Big kevs performance has a smoking deal on +1.5 intake & +1 exhaust. And a real fair price on doing the work. Also 100 on springs
front diff ,well I'm kind of hard on her.Only place to ride here is Randolph ORV,check on youtube about that. Exstream Off Roading @ ORV Randolph Ks. 11-06-10 And I run Outlaw Radials.Fuel pump went out a year and a week after purchase.I'm on 7:20 ,that little creek dose'nt have a bottom.You never know what you'll see at this place.
