Any one know of a block heater, dip stick heater, etc? My 09 Sport sets in unheated garage, starts but doesn't want to.
you can buy a stick on grid heater for an auto engine and stick it to the crankcase somewhere. Check Northern Tool out. They make different sizes, I have some larger ones on my diesels in my boat along with the block heaters. It makes those Detroits fire up quick!
Not sure if your FI or not. I found with my 2010 that if I let the pump cycle twice before I try to turn it over it seems to start ok. The way I define that is turn key on do not crank motor. Let all noises stop. Shut key off and repeat. Then try to start. Yes I know the KEBC is doing its dance in there as well. I found anything colder than minus 20 C it needs that for some reason. Give that a try and see if it helps.
