I just joined this so if I am doing something wrong here, just let me now or ignore this. We primarily are getting a 2015 2 seat that is:| used and because my wife went nuts over the camo. 99% of the use will be around our ranch hauling hay, shavings, etc. The only issue for the wife is pulling up alongside a horse corral and needing to open the door. This puts the load further away because of the door. No difference to me but she is probably right. The doors on it are factory hard doors.
Bill Bevan
[email protected]
Remove seat cushions,remove the 4 bolts on each side that hold down the seats and remove both driver and passenger seats.Dont forget to unplug the seat belt wire on the drivers side.Remove the plastic pins on the console.The 2 smaller knee covers located on the left and right side of the console have smaller pins.The trick is to take something with a small tip and push in on the pin and it should release(8 all together).Remove screw that holds shifter knob and remove knob.Pull emergency brake all the way up pull console off.Hope that helps.
