My 2010 teryx with 25hrs. (new left over utv) upon cold start takes several minutes to warm up before it will take the gas without poping and spitting. I cleaned the gas tank and made sure the vent line was open. after warm up it runs fine.
Probably not much you can do about it really. The ECU has a cold start function that you can't do anything with. Unless you have a sensor bad which should light the FI light on the dash then just live with it since it is only cold.
My EFI brute does same thing and I promise you it is tuned perfectly
