Hi, this is my first post here hopefully you guys can help me out a little.
i have a custom 2 seater buggy constructed by a kawasaki engineer using 100% kawasaki parts. teryx750 engine and chasis.
he put allot of time into the thing. but the carbs need to be re-jetted.
it has a custom 2 into 1 exhaust (headers are About 3 feet and 4 feet long) almost a foot different from one another. does that matter?
the air filter box is removed and has a K&n filter in a position where it gets more than enough air flow.
i heard stock jet size is 135 and 140, i need to do a little trial and error, what would you guys suggest starting out with? (jet sizes)
Lots of factors, altitude etc.
Which carbs?
An air fuel gauge will help you jet it, but the jet #s seem real low.
Sounds like you need a air fuel guage for sure. The exhaust that has the shorter pipe may be running lean from what i have learned (if i am correct) unless it is all runing fat because of the loinger pipe. Im sure an expert on this will chime in. Good luck
