You can't do without the puller and the spring compressor can be made but it is neededDo you have to have the puller and spring compressor to install the Dalton clutch kit? I just ordered the kit but I didn't get the special tools.
Sorry to butt in on the thread but I was wondering if a hydraulic press would do the trick compressing the spring.You can't do without the puller and the spring compressor can be made but it is needed
OK rite on I should be able to whip somthin up for that, just got to pick up a puller sometime. thanksSure but you have to press outside while inside comes thru and take a snap ring off
