What do the screws, that go along the top of the dash screw into? Is it a metal nut or plastic? If it is a metal nut is it on a metal bar, or again just plastic?
I want to fab a small gps mount & secure it with a couple of bolts that run along the top of the dash. It's a small hand held gps, so the weight and size are minimal. If the screws go into plastic then I'm gonna have to think of another route.
Their threaded metal tabs that pinch on to the plastic lip. They should be sufficeint enough for what your wanting to do.
Did you see how Rutcutter mounted his handheld...pretty clean as well if you need any other suggestions!
I did a search looking for Rutcutters mount but was unable to locate anything. Got a link?
