does standard bore kit use same fuel map as non std bore. the mods are msd, muzzy exhaust, and larger injectors. the injectors were installed with std bore kit.
Absolutely not, you need to get it tuned or get a map for the standard bore kit, and by the way you don't need injectors for a plain jane standard bore kit. They will probably cause fueling problems for you.
