Quick question in regards to dual battery setups.
For those of you who have incorporated this into you machine, how did you do it? Did you run the batteries in series off of each other, or is there some sort of block that needs to be used? Also, where did you mount it considering the factory battery is under the drivers seat.
Also, can I assume the stock alternator is not sufficient to charge both batteries, am I correct?
With that said, those of you running HID's or LED lightbars, are you using dual batteries or are you running off the single factory battery?
