1 - 1 of 1 Posts
I just installed a set of Eagle Eye lights on my 2012 Teryx4. There are some problems that ya’all should be aware of:
I had to remove the hood, Headlight shrouds, headlights, hinge brackets. Then fabricate a bracket and mount the ballast on the hinge bracket. There was no other place to mount it solid with the short wires they supplied. The process took about three hours. I then had to readjust the headlight aiming.
Plug and play is only the wiring. Instructions were flaky.
My light switch is not dim and bright; only bright and bright.
There is reduced side light, more straight now.
I had a 2010 RZR prior and installed a Halogen bulb that worked better.
Wish they made one for this rig.
1 - 1 of 1 Posts
