I went and rode a couple hours and it cycled like normal. I loaded it on the trailer and turned it off, the fan was running. Still running and it has been off for 2 hrs. Any ideas?
Hard to say ... this is why we are offering a killer temp gauge kit. The kit will come with a switch that will allow you to turn on the fan at any time. Plus the switch will have a light so when the fan comes on the light will also come on. It should be all done in about 3 weeks.
CLICK HERE FOR COOL TERYX PARTS
run, don't walk directly back to your dealer, there is deffinately something wrong with the sensor or fan. Either way it will be covered under warranty.
will it also be temp controled? By the way the Teryx is only a day old with 3 hrs on it.
Dasa said in an earlier post that it "yes" is still temp control, major advantage that you can leave the fan run longer if you so desire, just because you turn the switch off...it won't interfer with normal operation of being temp control.
Also remembered and earlier post...(?can't find it?) someone had said the relay had got wet and stuck on, sounds like it is in the relay though.
Thanks for the advice. It ended up being the fan switch in the radiator had a loose connection. Thanks guys
