Hubcap, I have the same tip that you have listed on your post and it does make a difference in the sound. It is a little deeper in tone but not real loud,and it seems to help the performance. I didn't use the screen that comes with it , so be carefull about spark arrester issues where required. You will need to use locktight on the bolts or they will back out and the tip WILL fall off.I did get lucky and a riding buddy found mine and we slapped it back on. I hope this helps.......................
I am running the same tip in your ebay link. It is not much louder at all and sounds pretty good. I also have the ebay steel power tip and it is a lot louder and about the same performance as the aluminum tip.
