What could cause HID's to flicker like strobe lights? They alternate from left to right for awhile when first turned on and you would think it was a police or emergency vehicle.
Are they direct plug and play meaning no relay?
Also not enought battery volts to fire the second one off.
Or bad ballast....
yes P&P, I'll charge the battery and see if that helps. I remembered that I did try to turn the lights on when the bulbs were disconnected once. Could this have damaged the ballasts?
Thanks for the replies
No porb... also I forgot make sure you have a good ground. Some ballast get funky after a while.
If you anymore issue call me Ill help you out.
