I am having an issue for an 2008 Teryx that when I first start the vehicle and put it into gear it will not engage and go forward or reverse. Often times I have to either push or rock the vehicle and that seems to help. Once it gets going then the issue doesn't seem to be a problem. Anyone else experiencing this?
I have replaced the belt once because I revved it too high once and it rubbed a spot in the belt. It was doing this before I ruined the first belt and it is now doing it after installing the second belt. It has less than 50 hrs on the unit. Thanks.
Maybe. I didn't do the belt so I'm not that familiar with the belt tension or configuration. I'll check it out. Thank you.
Correct, I am referring to it shifting into gear but the vehicle will not move. I assume it is because the belt is slipping? Not sure. However, it does physically shift into H, L or R as it should. Thanks.
