.Ok I was cleaning my teryx the other day and I saw a cable with some sort of leather wrap at the end. I removed the wrap and found an open connector and left me scratching my head wondering what on earth is for. Does anyone here know anything about it?
Its sounds like you found there reverse indicator switched plug, its a switched ground. Used mine to wire in a reverse light, make sure you put in a relay as the switch can't handle much current.
If a persons uses their Rex at night back up lights to me is a must, I use my Rhino for hunting and have the bu lights, I also like a light up high so you can see in the back, it can either be switched with the bu lights or switched seperate.
Ok Cool. Sounds like I found a new project then, I want to pu a work light in the back but I'll wire that one separate.
Rex Runner, Can you elaborate on the Relay. Backup light will be one of the next upgrades. Just mounted a new front bumper and WarnRT25, Wiring the winch right now. (waiting on cordless to charge) Would like to put in reverse light before I install new Full Belly Skidsand A-arm guards. Do not want to burn up mverse switch.
Alo do you know which wire in the dash is a good one for the "key On" power for the winch switch?
