Is it ok to use the original clip on the front axle splines that go into the diff? Or do i need to buy a new one?
I reused mine and the axles haven't fallen out yet. Just squeeze the clip a little to make sure it is tight on the shaft or it may be a**hole going back in and coming out the next time it gets pulled.
I figured it would be ok, just wanted to verify. Thanks. Hope i won't have to pull them again.lol. But we all know better than that.
I reuse them if I can but I have run into a couple that stetched pretty bad coming off and I wasn't confortable reinstalling them.
Thanks guys. Are the axle nuts any kind of special nut? I think the ones on the Rhino's are a one time use nut, just wanted to make sure the Teryx's are not the same.
