2011 teryx park brake pedal is up and light is off, but brakes are stuck on a little I can not move it in neutral and it labors to drive It how can I unstick it
thanks
Start with the obvious, if its cold where you live thaw everything out. Then lube the cable and return spring and all the brackets and see if that works.
