I just installed one and it sounds good and runs good. BUT the muffler gets so hot at full throttle half the muffler turns white hot. Does anyone else have the samething happen? The stock muffler dosn't do it.
Did you jet the carbs? Running lean will make the pipes glow. Air leaking aroung the rubber tubes on the carbs? Be careful dont want to melt a pistion
I rejetted and no airleaks.All I have is CDI , Hunter jet kit and Gibson muffler. I'm going to try a 145 pilot jet because it pops on decell, and i'm going to try 146 main in the front carb and a 150 in the rear. Everything was fine till I changed the muffler.
