Was out last night for a night ride and wound up stuck, as soon as i would try to run the winch in it killed motor, eventually i killed battery and had long walk home to fetch truck at about 2am. i suppose if i had used free spool to pull cable out that might have saved me but still. Anyways i am gonna get a new battery and suppose it will be optima since thats whats available at my parts store and was wondering which yellow top i should get, i have hid headlights, 2 55w back up lights, some led interior lights and a radio with 2 speakers, and do a good bit of night riding. nothing there seems to crazy to me to draw down a battery and i thought the smaller d51 should work but wanted some opinions. the 51 is like 450 cca and weighs 26lbs and the 31 is i think 750cca and 46lbs so a little weight difference and also smaller one is cheaper but let me know what u guys think.
I just picked up one of these today and have 2 hid's, 1 32" led bar, 2 4" leds, lighted whip, dome light and intercom. I will put it to the test next week at Glamis and let you know how it does. It is from Batteries Plus.
X2-30LA X2 Power AGM Battery 750CC 2008 to 2010 Teryx All Models Utility Vehicle Kawasaki ATV
750CC 2008 to 2010 Teryx All Models Utility Vehicle Kawasaki ATV X2 Power AGM Battery X2-30LA. The X2-30LA has specific dimensions of 6.63" x 5.19" x 6.875". A spacer is included to increase height to 7.75". X2 batteries offer the best features; fully sealed - maintenance free, pure calcium-lead plate design for increased power, easy to install with front mount threaded terminals and extended reserve power for more accessories. Backed by a full 24 month warranty, the X2 is the performance battery you have been seeking.
Item number: X2-30LA
Weight: 21.7000 lbs
Voltage: 12V
Capacity: 26AH
CCA: 400
Weight: 21.7000 lbs
Voltage: 12V
Capacity: 26AH
CCA: 400
This is the battery we sell and have had very good performance from them.
I recently put in a Optima Red top model 34-1056. It is a full size car battery and is a tight fit but it is way more than enough to keep me running and the winch. I will post pictures of how tight it is when my post count gets high enough.
