I Just Bought A Dragon Fire Racing Dual Exhaust And Air Box . Does Any One Have The Same Set Up? Because I Need To Know What The Jetting Should Be
Welcome to TeryxHQ.com!
First off, what sort of airbox is it? Like an aFe? or a aftermarket filter in your factory airbox?
Dragonfire should have included the proper jetting or at least gave you the correct jetting needed. I would call them back.
I am surpirsed that the info wasn't in the kit. Have you called yet and found out what it was supposed to be. I look forward to hearing how it runs once it is dialed in.
Well here is what I can tell you. I am running the aFe airbox, and am running the DynoJet needles with the clips at position two, DynoJet 155 and 160 main jets, and the screws backed out three full turns. Once our exhaust comes in and I install it, the machine will go down to be tuned on the Dyno. Maybe go one size larger than me seeing as you have the exhaust. Keep in mind, those are DynoJet main jets, therefore, the numbers are different then Keihin.
