I have a 2009 Teryx that won't start. Battery, ground and selonoid are good and replaced the starter. It will only click, does not turn over. Is there something in the gear box that is locked up or possibly the engine? How can I tell?
No. The last time it was used, we drove it up on the trailer and it hasn't started since then. I have 13.6 volts going to the starter. When I turn the key on, the voltage drops to 6.4. I have turned the starter gear several times and one time it tried to turn over. Do you think the starter clutch is locked up or could it be a voltage problem? Thanks!
