Hi everyone. I'm from NH and own a 2009 Teryx I use to groom snowmobile trails with. This thing gets a serious workout, trust me! I bought mine used with quite a few miles and it def. needs some mods and attention. Any and all feedback will be graciously appreciated. Thanks. J. Fulton.
Welcome to the site. What would you like your teryx to be better at ? There is no end to the mods you can do, but there is a beginning and the first mods you do are done to achieve a desired outcome. What is your desired outcome ?
Welcome to the site. What would you like your teryx to be better at ? There is no end to the mods you can do, but there is a beginning and the first mods you do are done to achieve a desired outcome. What is your desired outcome ?[/Q
My Teryx has 300o+ miles, 400+ hours. Uses half quart oil to every 5 gallons of gas. Have problems with the bevel drive gear/final drive. I need to pull the engine to repair this, and im thinking it's due for a complete overhaul. It gets very hot when pulling the 6x8ft multiblade drag. Very mountainous where I drag. Am considering a muzzy big bore kit 840, and exhaust? I am concerned the extra compression, will come with extra heat. It should have the upgrade for the cooling system now. What are your thoughts.
