1 - 11 of 11 Posts
Made my own clutch puller and a piece broke off inside - i can't get this piece out, can't get the pulller in because of this stuck piece- is there Any and another way to get this thing off?? Tried banging on it with a rubber mallet, tried hooking a winch up to it - this thing just won't budge!!
Any suggestions??
I got it off, put heat to it and keep tension on it with a winch and used a dead blow hammer. I thought for sure I was __________ big time.
I made it from a threaded bolt and a metal rod. It worked on mine and a friends a few times. This time the metal rod bent and got stuck inside. I was adjusting the belt, im running EPI's lime green and maroon springs no problems in 110 hours.
1 - 11 of 11 Posts
