okay guys i'm currently rebuilding my top end. i have ordered the FST Std bore kit and full muzzy exhaust. im a bit confused on what intake to use and also what jet kit to use. Could someone point me in the right direction to what setup to use? i already have the dynatek and vforce stage 3 clutch. im ready to hear this teryx rip. i should be able to hit 65 after its all set and done?
If you are changing intakes search for a thread on Poflo style carb mod.
If you have carbs - air fuel gauge will get you jetted correct.
yes i do have the 08 teryx which is carb. i do plan on keeping the stock box but due to all the dust in louisiana on the trails. i want to minimize the dust from getting sucked up. This is what destroyed my motor which is why i have to do a rebuild on the top end.
Yeah you should hit 65. I hit 67 and all i have is the muzzy,overdrive plate. dalton clutch, uni filter and msd ignition. I have never been in motor yet but will in the future.
