Just installed a High Output Fan and the radiator fan by-pass switch in my 08. The factory fan seemed to run constantly during low speed rock crawling or when climbing hills and now the fan runs at most 2 minutes after a hard hill climb in the sand, keeping my engine cool. I am impressed with this fan/switch combo.
Now to install the high volume water pump and find a good temperature gauge ... anyone have any suggestions on the gauge and wiring?
I've got all the above except the gauge and it made a world of difference in 100 degree heat.
I have the high volume pump here waiting to be installed and think that will help even more. With the fan I went with the shroud modification where I could use the shroud with the new larger HO Fan, what a difference that made.
Where did you guys pick up that black rhino gauge?
I got the livorski marine guage kit from sidebyside.com if i am remebering correctlyl
Where did you get your high output fan from?
Yeppers, Todd at Hunterworks has been getting my spare change ... try to spend it with him before Washington takes it :D
