Can someone please explain how to remove the front driveshaft? I need to replace my front diff seals. Thanks.
Got it. Here is the procedure I used. Hopefully it will help someone else.
Remove the front driveshaft tunnel.
Push front drive shaft forward (into the front diff), it will slip out of the transfer case.
Push off the inside "C" clips from the front U Joint and remove from the front yoke.
Remove front yoke.
Pry out seal from front yoke and front diff housing.
Install new seals and reassemble.
Not too difficult to do other than you don't have much room.
