I finally got the Teryx 2" lift kit installed yesterday and did our install video. I will have to say it was one of the easiest lift kits I ever installed and works great. The quality of workmanship is simply outstanding.
The kit is from Xtreme lifts
I measured a true 2" in the rear and 3 1/2" in front. My teryx sits level now.
Works great, made HD. It will be on the site monday along with the install video.
Discussion Starter · #4 ·
I just got back working in the shop after my wreck and I needed to get a few small items done first.
I will be out of town for the most part over the next two weeks so my plan is to tackle the exhaust, belt adjustment and install video, clutch kit test and install and the overdrive clutch cover test and install video.
I might should get the Gibson slip on tested first so when I pull the stock system off I won't have to put it back on.
Are you testing any other pipes? Decible posting would be cool too.
Stock, baffle removed and tip, Gibson Muzzy, etc. Oh yah, thank you in advance for testing them.
Discussion Starter · #6 ·
No decibel testing, I don't have that equipment but I will tell you if it is loud or not.
The plan is to test a muzzy, hmf two into one full system, a gibson slip on and a two brothers dual set up.
It is not the brand I am testing it is the design. I personally feel no matter whose exhaust it is as long as it is designed the same meaning like a true dual they will perform about equal.
Thanks again Todd. A bench mark from stock and with the stock baffle removed/$35 tip would be great.
I'm betting a few pipes are overstated in hp gains. Hope I'm wrong though.
I was reading somewhere??? - maybe on this forum but they where talking about the Gibson slip-on making 0 gains on the Teryx. Maybe they didn't do something right with the tuning or don't know how the where testing. I was looking at buying one because they where stating on their site the decibels and it was not much louder than the stock system. Appreciate all the info you put on this site Hunterworks.
I'm anxiously awaiting these test results too. It will be awhile before I'll be able to buy more than a tip, but at least it will be good to know how much money I want to put towards an exhaust system after hearing an unbiased report.
