I came in this am and put the quiet core in the Swamp Series from HMF and re tested it.
It is quieter. 92db at 6000rpm and 98db under load.
HMF claims no loss in power and if you looked at peak HP then you might agree but at 35 mph the curves start seperating showing a clear loss using the quiet core over no core with a net loss of about 4 hp at 52 mph..
Below are the tests which compare the Swamp Series and the XL
First test is the standard dyno run and the second is our loaded test.
