I put a horn on mine I put a button in the dash next to the ingestion where the round bump is (on a 2011) and then put the horn up under the hood by the hinge by he radiator. I would post some Picts but I'm not sure how to do it. Hope this helps
Need help installing after market horn on 2013 Teryx 750?
What do you need help with? If its finding power source use live wire coming off your cigarette lighter. Only live with the key switch. Easy to get at if you remove the firewall panel under the hood. Couple of push pins removed and your in there. Easy to route wires to horn if you're mounting it under the hood.
I didn't ask the question, but I sure do appreciate your answer. I was looking at two unused holes in the ignition block. It looked to me like they might be switch-wired if I could get the connection apart and remove the rubber plugs in the holes.
