Hello all, I'm new to the forum and a relatively new teryx owner, I own a 08 LE, some mods, 2 bros exhaust, jetted, dynatek, but my questions are about a compression worry I have, it seems the front cylinder has much less compression than the back cylinder when cranking, haven't done a compression check yet, just did the pinky in the spark plug hole, front cylinder I can completely plug when cranking no problem, but the rear will blow my pinky out, and when running at idle, the front carb slide bounces, and the rear does not, I'm new to these v twins but comparing mine with a 2011 I drove today just to compare, mine has twice the power of the machine I drove today, no smoke or any starting problems either, do these things sound normal? Any help would be appreciated! Thank you.
Discussion Starter #2
Any Takers? Over the last few weeks I've noticed it is kind of a bear to start cold, but once warmed up it starts just fine.
