Actually the jetting part is easy, the semi tough part is getting those carbs off.
You can leave the carbs joined together, however, you will need to remove the throttle cable (access this by removing the panel on the drivers side) You will also need to remove the various hoses from the carb as well as the choke cables (which are held on by brackets on the side and rear of the carbs. I can provide you with a disassembly sheet if it would help you.
What mods have you done that you are rejetting? With the open airbox design I am using, I am using a DJ150 main jet in the rear carb and a DJ146 main jet in the front. In addition, I am using Dynajet’s needles with the clip in the second position. Mixture screw is backed out three full turns from lightly seated. These main jet numbers do not correspond to the Keihin main jet numbers.
I am thinking I am still running a tad lean (where I live is approx 1400’ above sea level) so I am going to have to go another size larger…that should do it.
