1 - 11 of 11 Posts
Hey guys i've been having problems with the main fuse popping. Before it would run for a while and the just turn off. So I would switch the fuse and go again.(i know its not right)now its got to the point where even if its off I go to put a new fuse in it just pops. I need some help 30 fuses and still no luck. Its a 2009 Fi teryx (monster edition) if that madders.
Thanks Guys
I had that happen on the brute force . A positive line was grounding out and thus blowing fuses.
Hey did yall ever figure out what the problem was with the main fuse blowing. Went to a fourwheeling event this past weekend and main fuse is now popping. Before it blew I had sprayed off the radiator since it was overheating and went out on the trail and it lost all power. Only things I have done are installed an Odyssey 1200 battery, a winch, and stereo. Any help appreciated.
Welp in case anybody has this type of problem, mine turned out being wet electrical plugs. Cleaned and greased the fan and headlights and it fired right up so I went ahead and dielectric greased every single electrical plug. Hope this helps someone one day.
1 - 11 of 11 Posts
