Anybody add a kill switch to their 'rex? Thought it may be a good to add some sort of hidden switch to prevent unwanted drivers.
I imagine that it could be done...I have not done it, but I would not thinkg it should be too difficult to cut power from the ignition with a switch.
And there you go...problem solved :good:
Thanks Uplink!
Here is what I found as a quick trick... More to come we have been busy at the shop.
Pull the plug and it wound crank over acts like a dead battery, easy fix just remove the seat and pull the connector apart. Will have a ingnition kill diagram in a few days after I tear another one apart. Its two White wires with a Red strip on top of the CDI.
More to come....
