Well my brother was the last one to drive it before it was stored all summer. Just went to pull it out and get it ready for the winter and noticed it would not roll.. I saw it was in high so I tried putting it in neutral and it will not budge. When I try to turn it on I hear allot of electrical noise but it wont start. I tried rocking it to get it out of high but nuffin.
Is it a problem if these are stored in High gear? Could it be a battery problem ( I have it on a charger now )
Ideas?
PS the motor is all stock
Could be something bad or could be nothing.
I think I would try to get it cranked first or at least I would.
What is this electrical noise sound like?
Once you get it cranked it might just pop out of gear and everything go back to normal.
If something is actually wrong with the tranny, the engine has to come out and be torn completely apart
Hopefully the belt is stuck? I agree I would get it started and see if it will move then maybe will work it out. Did you check the oil?
