I am looking for a fuel cell the replace the stock one under the passenger seat. Would like to put the new one in the middle behind the engine. Looking for manufactures, guidance and anything else.
That fancy machine still has stock fuel cell? You should ask for your money back:D Check out the RCI website, find a size that works for you and call Gee & Gee racing in leduc they can get it for you. 780 986 7223
i am running a 12ga RCI tank in mine from summitt. it turned out to be considerably easier to install than i expected. i also picked up the rci mounting straps. i went with the poly style tank. works great.
anyone running a fuel cell on a 2009 and over i would like to know how everything for the fuel injection fits into the tank and what kind of tanks everyone is running thanks
simple way would be to spec a cell out with the same depth as stock and then just mount the stock system into the new cell....
otherwise you need a stanf alone fuel pump and then a new fuel sender.
