i had been riding last week end and i went to start my ride back up and i had no power whatsoever..the dash wouldnt come on or anything.i had checked the fuses and they were all good.anyways...after checking the plugs under the seat..i found that the 2 wire plug going to the starter solenoid was corroided and not making good connections.i had to cut it out and wire it straight..i soldered them up when i got home and havent had any problems since.anyways if anyone has lost all power to their teryx..better check that plug.it will kill all power to the teryx.has anyone else had this problem?thanks again guys.
I had almost the same problem. I had some power with the key on, but not enough to run the winch or turn the motor over. It was the negative battery calble end at the battery.
