So I took advantage of the rain this weekend and installed a UTV Machined Clutch Cap and a Dynatek CDI. WOW! What a difference in performance. I can now easily go 35 MPH in Low and over 55 in High. When I put in the O.D. Cap I didn't have a torque wrench so I snugged up the perimeter bolts about as tight as I could with a 3/8 drive socket. For an example.. about as tight as you would make a spark plug. Someone said the torque should be 7 lbs., which is scary loose in my opinion. I didn't use loctite either which may, or may not, have been a good idea. Not sure? I have a fear of bolts coming loose in there so I may have tightened them a little much. Not sure there either? Machine runs great though. Any opinions on the bolt tightness is appreciated.
