1 - 13 of 13 Posts
Bought Dasa's impellar, installed yesterday, thought I would let her sit and idle after I burped the cooling system to see if me new part solved my temp light problem and---well the light still kicked on may have taken a little longer, but I probably drove it to get the rpms up for 2 minutes before the light shut off, and I did have my cooling fan on, it is wired to a rocker switch to run at the push of the button, which I turn on at start up, so I would like some input how else I can kick that light issue, thought the impellar was the fix but still a issue, thanks for any input, not sure if the digi dash/sensor for temp is bad, or what
How exactly are you burping the system. I have found that after you burp it with the burp scew at the thermostat housing you also need to jack the front up or park it on a angle to get additional air out. Also how many times in the past has it been hot. These motors will blow the head gaskets easily when hot. When you burp it with the front end up at an angle and it constantly pushes up little bubbles that may be a sign that the head gasket it leaking combustion into the cooling system. Feel free to call me if you like, beleive me I am well versed in Teryx heating issues.
unleashed......what is the main factor you have run into on the teryxs overheating?big bores?clogged radiators?lean engines?
Have you ever thought the radiator might be clogged with mud?
Also these impellers really can't make it run cooler since there is a thermostat, if it is closed water does not flow until it gets hot enough to open.
Once open the higher volume pumps will get temps back down quicker and the fan does not stay on as long.
On burping it, we simply don't fill the radiator all the way up but almost up and let it idle once the thermostat opens we look for water flowing thru radiator after letting it flow a few minutes then fill all the way up. Never had a issue yet.
When DASA installed my Impeller they found a black coating "like plastic wrap chips" in my Rad. Don't know what kawi coats with this stuff but if flaked off and got in my rad. Flushed out system with no problems.
I have a 2009 Teryx and I just put on a Muzzy dual exhaust and a Muzzy ignition, Now it is popping and backfiring and even seems to be running a lot hotter. The Teryx died on me today when sitting idle and my oil light flashed. What do I do now???
Please help
Bought Dasa's impellar, installed yesterday, I burped the cooling system to see if me new part solved my temp light problem and---well the light still kicked on may have taken a little longer
I have found on a few builds that once the temp light has come on it is toooooo late. Those cars needed new head gaskets. They would run fine, but temps would get hotter faster.
The impellers make these cars run cooler ... NO QUESTION. The thermostat opens yes ...... then these pumps move more water and keep the cars cooler. We have tested it over.... and over ... and over on many builds.
So it is not running now?
Yes it is running and all fluids are full. Its just not running good. Its seems hotter and when I let off the gas it backfires or when I am going down a hill off the gas it backfires all the way down the hill. It sounds good when I'm on the gas, but seems to be running hot.
Backfires either means leaking exhaust which is highly likely and running lean.
Running lean might have something to do with your heat issue.
So will that cause major problems and how do I fix the problem? I thought the MSD would fix the lean problem.
Thank you for your help
1 - 13 of 13 Posts
