I been stuck in a mudhole two different times when im gunning it trying to get out of the hole and let off the gas the teryx cuts off in gear and i have to winch it forward so i can get it in neutral to cranck it back up.It only happens when im good and stuck as long as im movving it does fine but if i started shifting back and fourth alot it will cut off in the mud in drive. Is there some kind of rev limiter that is doing this. Has anyone else had this problem or no how to fix it.:mad:
Check if you are getting oil in the intake. May be due to high rps then letting off and that basicly floods it out with oil momentarily on your way into the mud.
Not sure I'm understanding everything but you do know it will start in gear, right? Just push on the brake pedal.
